Hi all,
This is my first post in the community! I have been sketching remodels on the backs of napkins since 2002 and have finally enrolled myself in a course for AutoCAD. How wonderful! We are spending the semester creating a hotel (see attached). I could use some support as I go along here if anyone can help I would greatly appreciate it.
ANGLE IN XY PLANE?
My bottom exterior wall is slanted and not straight/horizontal! Now that I have xref'ed my grid into my floor plan, I notice that my bottom exterior wall is at an angle instead of straight. When I use the LIST command on that line, I confirmed that my line is slanted (see below info). My questions are:
1. Why does Angle in XY Plane = 0? What does that mean?
2. What does the Delta mean?
LINE Layer: "A-WALL-EXTR"
Space: Model space
Handle = c81
from point, X= 0'-0" Y= 0'-0" Z= 0'-0"
to point, X= 211'-8" Y=-0'-4 5/8" Z= 0'-0"
Length = 211'-8", Angle in XY Plane = 0
Delta X = 211'-8", Delta Y = -0'-4 5/8", Delta Z = 0'-0"
DIMENSIONS DUPLICATED AND BRIGHTER GREEN ON TOP/HORIZONTAL
If you look in my attached drawing you will also note that the dimensions I added at the top are brighter green then the dimensions on the left side AND duplicated.
3. Are my dimensions incorrect at the top? If so what should I do to change them?
