Anuncios
Lisp Routine for Plotting a Cylinder with 2 different points and levels
jaspal_sandhu1
jaspal_sandhu1
Hi
Does anyone know of a Lisp routine that will help me plot a cylinder with given Eastings, Northings and levels from a excel table? I can plot the line and then draw a circle to then extrude a cylinder and follow the path of the line but its time consuming when i have so many to do, hence the reason why i need a lisp routine that will automatically plot eastings, northings, levels multiple times.
Thankyou in advance.
0 Me gusta
Responder
252 Vistas
2 Respuestas
Respuestas (2)
CodeDing
@jaspal_sandhu1 ,
There are multiple posts about reading either Excel or, preferably, csv files. Once you have your data from your file, this function will create your cylinder on the current layer. Just pass your 2 points into it:
(defun 2P->Cylinder (p1 p2 / cylinderRadius)
  (setq cylinderRadius 5.0)
  (if (and (apply 'and (mapcar 'listp (list p1 p2)))
           (apply 'and (mapcar 'numberp (append p1 p2)))
      );and
    (command "_.CYLINDER" "non" p1 cylinderRadius "a" "non" p2)
  ;else
    (prompt "\n2P->Cylinder error: Bad point(s) provided.")
  );if
);defun
LM Read CSV
Useful Functions
ALx Functions
Hope that helps.
Best,
~DD
0 Me gusta
Alfred.NESWADBA
are you referring to boreholes?
If yes I would suggest to use Autodesk Civil 3D and it's plugin >>>Geotechnical Module<<<.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
