LISP Prob1 - Opening a file
LispResearch
LispResearch
Greetings dear AutoCAD gurus,
My goal is to make a LISP script to open a file with dwt extension as if I would open it through "new" button. That means that it should open, and not with .dwt extension but with dwg extension. I want that for creating some buttons for different templates.
I tried to find answer on the forum, but I am sorry I could not - there are many examples that should work but they don't in my case.
These are some short scripts that I tried:
1. Using the Open command: (command "OPEN" "C:\ACAD_ISO_ANNO_B6_A3.dwt")
And the result is that Autocad says that dwt is unknown command like if it recognizes the period symbol inside quotation marks for system symbol.
Here is a set of command line strings I get:
=== START ===
Command: (command "OPEN" "C:\ACAD_ISO_ANNO_B6_A3.dwt")
OPEN
Command: C:ACAD_ISO_ANNO_B6_A3.dwt Unknown command "DWT". Press F1 for help.
Command: nil
=== END ===
2. Using vla function: (vla-open (vla-get-documents (vlax-get-acad-object)) "C:/ACAD_ISO_ANNO_B6_A3.dwt")
The result is that it opens the file but as an original template with dwt extension. Whereas I want it to be something like Drawing1.dwg.
My question or request is if it is possible to solve on both and how, what am I doing wrong?
Signature:
Interested in Lisp
Alfred.NESWADBA
not read all of your post, but the first guess with the LISP-statement: To use path-separator in LISP you need either / or \\ (slash or double backslash).
So change the code to:
(command "OPEN" "C:\\ACAD_ISO_ANNO_B6_A3.dwt")
or
(command "OPEN" "C:/ACAD_ISO_ANNO_B6_A3.dwt")
And let us know if that work's for you.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
LispResearch
To be true I tried these variations before, but forgot to write, anyway here are the results in command line:
A1. when I use (command "OPEN" "C:\\ACAD_ISO_ANNO_B6_A3.dwt"):
Command: (command "OPEN" "C:\\ACAD_ISO_ANNO_B6_A3.dwt")
OPEN
Command: C:\ACAD_ISO_ANNO_B6_A3.dwt Unknown command "DWT". Press F1 for help.
Command: nil
A2. when I use  (command "OPEN" "C:/ACAD_ISO_ANNO_B6_A3.dwt")
Command: (command "OPEN" "C:/ACAD_ISO_ANNO_B6_A3.dwt")
OPEN
Command: C:/ACAD_ISO_ANNO_B6_A3.dwt Unknown command "DWT". Press F1 for help.
Command: nil
An additional thought from my mind: Can the switches or variables be the problem? I was editing some switshes to customize and optimize my AutoCAD but I use it for about 2 years from installation and do not remember what I changed.
Signature:
Interested in Lisp
Alfred.NESWADBA
tried it now, seems like (command "_OPEN" ... does not work with extension DWT.
Maybe >>>that blog<<< shows you how to create new drawings based on a specific DWT.
Good luck, - alfred -
Alfred NESWADBA
LispResearch
Yes it does exactly what I want. Thank you Alfred.
Sadly, that could not find a solution to "open" command usage. Sometimes it seems that it is simple I just don't see some quotation mark r bracket or something should be added but probably not in this case.
The main problem is solved.
Signature:
Interested in Lisp
