Lisp - Create Circle Then Trim & Join
putrokasi49
putrokasi49
Community Visitor
Community Visitor
I have occasions in my drawings where two lines intersect and I need to create a "jumper" where one of the lines jumps over the other. What I typically do is select the intersection, create a circle (whatever diameter I want), trim said circle and line to create a jumper then join first half of the line, half circle, and second half of the line to create a polyline. This seems really simple but I cannot seem to figure it out in AutoLisp. https://routerlogin.uno/
cadffm
Look for the dedicated Lisp forum, if you want to ask/learn lisp
https://forums.autodesk.com/t5/autocad/ct-p/8
>>" This seems really simple but I cannot seem to figure it out in AutoLisp."
You forgot to post your code(?) where do you stuck?
I used my favor internet search engine,
my first try was:
AutoCAD Lisp Cross Lines Arc
my first hit:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/crossing-two-lines-with-arc/td-p/106...
So, search for it, you will find a lot of snippeds and whole working codes.
Sebastian
Valentin_CAD
@putrokasi49 ,
Welcome to the AutoCAD forum!
Try the Autodesk App Store.
See if this app helps:  CrossWireS
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
