LISP: Autocad crashes on lisp
I want to freeze a layer (language layer) for a complete folder of DWG's.
I've found a working LISP to do what i want so no problems there.
NOW:
I've come up with the idea to let the user choose in which language they want to work by asking this through a Dialog box.
When I start the command "Set_language" the box with the language selection pops up. So far so good.
After I click a language (just NL for now), I get the folder selection window which is also very good.
But when I select the folder with the DWG's en press OK, autocad hangs itself followed by a fatal error.
I don't seem to find the problem in this but i think it has something to do with the fact that the Language selection window stays open.
Also, I can't seem to put my "DONE" signal  (prompt or alert i haven't decided yet) at the end of the routine.It pops up right before the routine starts with processing the dwg's in the chosen folder.
Does anyone know how i can fix this? I tried a few things but my knowledge of lisp is very limited and i'm out of ideas.
Thanks in Advance,
LISP code below:
;;;; ROUTINE TO CHOOSE WORKFOLDER
(defun BrowseForFolder ( Message / sh folder parentfolder folderobject result)
 (vl-load-com)
  (setq sh
   (vla-getInterfaceObject
     (vlax-get-acad-object)
       "Shell.Application"
   (setq folder
      (vlax-invoke-method
          sh
          'BrowseForFolder
          0
          Message
          0
   (vlax-release-object sh)
    (if folder
      (progn
         (setq parentfolder
           (vlax-get-property folder 'ParentFolder)
        (setq FolderObject
           (vlax-invoke-method
              ParentFolder
               'ParseName
              (vlax-get-property Folder 'Title)
       (setq result
          (vlax-get-property FolderObject 'Path)
       (mapcar 'vlax-release-object
         (list folder parentfolder folderobject)
     (if (/= (substr result (strlen result)) "\\")
       (setq result (strcat result "\\"))
       result
); defun
;;;; DEFINE FUNCTION AND CALL DIALOGBOX;;;;;;;;;;
(defun c:SET_LANGUAGE (/ dcl_id)   ;define the function
  (setq dcl_id (load_dialog "DB01.dcl"))  ;load the DCL file
  (if (not (new_dialog "DB01" dcl_id))   ;load the dialogue box
    (exit)      ;if not loaded exit
  (action_tile "cancel" "(done_dialog)")
        ;if Cancel button selected, close
              ;the dialogue.
  (action_tile "NL" "(done_dialog) (set_NL)")
       ;if NL button is selected
  (action_tile "FR" "(done_dialog)")            ;if FR button is selected
  (start_dialog)    ;start the dialogue
  (unload_dialog dcl_id)   ;unload the dialogue
  (princ)
)      ;defun
(princ)      ;load clean
;;;;:DEFINE ACTIONS;;;;;;;;;;;;;;;;;;;;
(defun set_NL ()          ; FUNCTION SET LAYER TO NL
           (if (setq DirPath (BrowseForFolder "Select folder of drawings to process: "))  ; ASK WHICH FOLDER
       (progn
    (setq DwgList (vl-directory-files DirPath "*.dwg" 1))    ;LOOK FOR DWG'S
      (setq f (vl-directory-files DirPath "*.dwg" 1))
     (length f)
      (setq ScrFile (vl-filename-mktemp "Batch_Dwg.scr"))    ; CREATE TEMPORARY SCRIPT
      (setq Ofil (open ScrFile "W"))
      (write-line "SDI 0" Ofil)       ; Force Multi-Document mode
      (write-line (strcat "(setvar " (chr 34) "FILEDIA" (chr 34) " 0)") Ofil)  ;DISABLE USERWINDOWS
       (foreach Dwg DwgList
         (setq FullPath (strcat DirPath Dwg))
         (write-line (strcat "_.open " (chr 34) FullPath (chr 34)) Ofil)        ;OPEN DWG
         (write-line (strcat "(command "(chr 34)"_layer"(chr 34)(chr 34)"S"(chr 34)(chr 34)"DRAW"(chr 34)(chr 34)(chr 34)")") Ofil) ;SET LAYER TO DRAW
         (write-line (strcat "(command "(chr 34)"_layer"(chr 34)(chr 34)"F"(chr 34)(chr 34)"INFO_FR"(chr 34)(chr 34)(chr 34)")") Ofil) ; HIDE LAYER "INFO_FR"
         (write-line (strcat "(command "(chr 34)"_layer"(chr 34)(chr 34)"T"(chr 34)(chr 34)"INFO_NL"(chr 34)(chr 34)(chr 34)")") Ofil) ; SHOW LAYER "INFO_NL"
         (write-line ".qsave" Ofil)             ; SAVE
         (write-line "_.close" Ofil)             ; CLOSE
      ); foreach
      ); progn
          (prompt "Done Processing Schemes!")     ;PROMPT WHEN DONE
   ); if
DCL FILE:
DB01 : dialog {
 key = "main";
 : column {
 : text {
 key = "Choose Your Language";
    : row {
 : spacer { width = 1; }
 : button {
 label = "NL";
 key = "NL";
 width = 12;
 fixed_width = true;
 mnemonic = "Y";
 is_default = true;
 : button {
 label = "FR";
 key = "FR";
 width = 12;
 fixed_width = true;
 mnemonic = "N";
 : button {
 label = "Cancel";
 key = "cancel";
 width = 12;
 fixed_width = true;
 mnemonic = "C";
 is_cancel = true;
 : spacer { width = 1;}
wispoxy
Is the file you're working with created with AutoCAD? The Error shows an unknown file being in the wrong place.
It's kinda weird, so let me give you a link with a guide all about it down to the very code that created it.
AutoLisp_Developers_Guide.pdf
Here is a great AutoCAD extension that you can use to accomplish this.
https://apps.exchange.autodesk.com/ACD/en/Detail/Index?id=appstore.exchange.autodesk.com%3Abatch-in-...
I've found a sluiten for my problem. Thanks for thema developpers Guide and the batch tool. I"ll take a look at it!
