Hello, I am using Autocad 2017 lt and I am just beginning to understand how to setup a datalink table.
I want to set up attributes that will collect dimension values that can be extracted to a datalink file such
that when stretching the block and the dimensions - say for the length - changes they will automatically
be linked to the attribute for my table data.
I don't know! Did I say that well enough for anyone to understand what I want to do?
Heeeeeellllllllppppp!
I am wanting to place attributes that are linked to my dimensions so that when I use the dynamic stretch command
and the height, or length, of my object changes that value is used to replace the previous dimension. For example: I have a steel beam that is
5'-0" long and if I have to change the length with the dynamic stretch command and the value changes to 5'-6" the value for that part reflects in the table automatically.
Thanks in advance.
