Linked Table Column Reformatting Bug
Tdevlin8A3RE
Tdevlin8A3RE
When linking an excel spreadsheet and formatting the spreadsheet as two columns, then scaling the table to fit the viewport, autocad does not keep the formatting on the second or additional columns after saving and closing the drawing. I've had this bug multiple times in the past and have only solved it by pasting the excel sheet as OLE, is this a known issue?
Initial Table LinkedInitial Table Linked
Formatted as Two ColumnsFormatted as Two Columns
Scaled to Fit ViewportScaled to Fit Viewport
Table after Closing & ReopeningTable after Closing & Reopening
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Tdevlin8A3RE,
Thank you for posting your question. That is unusual and not a known issue that I am aware of.
It kind of looks like it might be trying to update the font size from the spreadsheet. Maybe lock the table cells after scaling?
If a post answered your question or resolved the issue, please click the Accept Solution button.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Tdevlin8A3RE
Hi Cheryl,
I tried locking a few cells' content and format but that had no effect. It doesn't occur without the table being scaled, but also happens whether the table is scaled up or down. I did a couple quick tests on how much the text height is changed if that assists anyone with troubleshooting;
Original text height: 0.11
Scaled Down to: 0.083
Reopened to: 0.1506
Scaled Up to: 0.1302
Reopened to: 0.2410
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Tdevlin8A3RE,
Thank you for the added information. That is unusual and sounds like something that might need to be logged. I encourage you to submit the issue through the Autodesk Product Feedback form.
All the best,
Cheryl Buck
