Link drawing to external data
Please excuse my newby language in trying to describe my problem. I searched for a solution and could not find it, maybe because I don't have the necessary "lingo" of the field. But hopefully you can point me in the right direction as I do hope that what I want to do is commonly done.
Say I have an AutoCAD drawing with lots of irregular shape hatch areas assigned to various layers.
I also have an Excel sheet with information that should be mapped to those hatched areas. Say one of the columns is "type" and based on that type I should place the hatch in a given layer in the drawing.
So what I am after is some guidance on how to go about:
- assigning some unique ID to the hatch (or accessing it if it automatically gets one on creation)
- export a list of hatches with their ID and current layer
- link (programatically?) the drawing to the Excel file so that on update the hatch moves to the layer commanded by the type specified in the layer
While searching for answers on my own I noticed that one can define blocks with attributes. That does not seem to be applicable here as I don't have reusable components (my understanding of blocks) but rather unique objects.
natasha.l
Hello @Anonymous,
Sorry. There is no hatch tool or feature for that kind of workflow. Its a great idea.
Looking around in the tool I found that I can attach something called XData to my hatch and then list it.
So I can use the int field to assign an ID and even store the layer in there (optional).
Command: xdlist
Select object:
Enter application name <*>: Test
* Registered Application Name: TEST
* Code 1002, Starting or ending brace: {
* Code 1070, 16-bit integer: 32000
* Code 1003, Layer name: Test
* Code 1002, Starting or ending brace: }
Object has 16330 bytes of Xdata space available.
Am I wrong to asume that I should now be able to iterate all objects that have XData in the drawing, using LISP, and move them to the desired layer?
Hmm, maybe I don't even need that since I can fetch entity's name as an ID using entnext & co...
JTBWorld
It can certainly be done with programming and if you would need help feel free to contact me.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
