Anuncios
Linework missing when plotting with sheetset when sheetset includes multiple files
Katiemcreasey
Observer
Katiemcreasey
Observer
Observer
I have a sheet set that includes about 15 pages. Eight of those pages are from the same drawing. If I include these eight pages in the same sheet set with the other drawings, most of the xref'd linework etc. (in model space) in the eight drawings does not show up. Some of the linework does show up (the linework on one to four layers, including linework and hatches), but the majority does not. Paper space always prints as expected. The pages from the other files in the set print as expected. If the eight pages are the only pages in the sheet set, everything prints fine. If I plot the sheets individually not using the sheet set, the pages print as expected. I've checked that linework isn't frozen, the xref is on/unfrozen, audited the files, and recovered the files. I've added the sheets to different sheet sets to double check that this is a consistent issue. I've also had the opposite problem in another sheet set for this same project where one of my drawings prints with almost all of the hidden linework on. Any ideas what could be causing this? I've attached a screenshot from the same sheet, one that prints as expected, and one that prints with a lot of missing linework.
0 Me gusta
Responder
261 Vistas
1 Respuesta
Respuesta (1)
sarahC6DTR
I can think of 3 items to check:
1. VP freeze on the paper space of that given MView.
2. SSM PDF publish settings
3. SSM page set up manager. Perhaps there's a ctb file issue.
The fact that when you publish regularly, it still prints correctly is what's stumping me (this would mean your layer properties, the default ctb of your page setup are correct, and not an LMAN issue). Have you done the old batch plot to see if it still occurs?
0 Me gusta
