Lineweights show in model and layout but not in print preview
Hello All
I have setup different line-weights for different text styles such as existing items (wt 0.15) and proposed items (wt 0.35), as well as a heavier weight for the border title (wt 0.70). The border and the border's content are in the "layout".
I can see the different line-weights in all views model and paper. But the actual print preview and paper printout show otherswise.
I have attached screen shot to show what I mean.
"screen shot 1" is shows the full screen with the wt 0.70 in properties.
"screen shot 2" shows the print settings used.
"screen shot 3" shows no multiple line weights.
Please advise how I might be able to proceed so the print matches the views.
screen shot 1screen shot 1screen shot 2screen shot 2screen shot 3screen shot 3
cadffm
Check your plotstyletable.
Or a short test:
Plot without the plotstyletable and DWG to PDF.pc3
Attach etransmit zip file and we can search the problem too.
Sebastian
Johanna_Esteban
Hello @Anonymous,
Please attach the file * .dwg, I want to verify layers properties.
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! 😉
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
Thank you for suggesting not using a plotstyletable.
I used "none" for plot style table then I used other none-OhDOT plot files and all provided good results.
My next step will be contacting OhDOT for feedback.
I don't see a need to send electronic files, but if you think it is still a good idea, please advise.
Best regards
Gabriel
cadffm
OhDOT?
I dont know, but
If you have the problem only in some plotstyletables, check the setting for Lineweights in this plotstyletable.
For example, an object with color 1(red) in your modelspace or color ByLayer and the layer color is set to 1.
Open the plotstyletable, click to color1, check the value for lineweight.
Sebastian
Thank you, I will look further into it based on your suggestion.
