Lineweights not plotting correctly as per CTB file.
Hi! Can someone please help me? I switched to a new computer and upgraded my AutoCadLT 2016 Mac version to AutocadLT Mac 2021. I uploaded my CTB files to the page setup manager. But when I plot to PDF all of my line weights are VERY heavy and illegible. I can't figure out how to fix this. When I look at the layers in model space, they are all set to DEFAULT. Not sure how to correct this. My new auto cad version is also saying that there is unsupported objects in the file. I'm not sure what this means or if it's related. If someone could please help, I would really appreciate it!! 🙂 Thank you!
imadHabash
i suggest to check from PLOT dialog that your plot option Plot with plot styles is selected .
Imad Habash
It is checked to plot to plot styles. Do you know what else it could be?  Thank you for your help!
vinodkl
See if these links help: https://forums.autodesk.com/t5/autocad-for-mac-forum/unsupported-objects/td-p/7005648
https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle...
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
GrantsPirate
In the plot dialog uncheck the Scale Lineweights box.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
YES!! That worked, thank you so much! It's a fabulous day! 😉
