Anuncios
Lineweights not displaying on 100% zoomed pdf
No aplicable
Lineweights are only showing up when I zoom in at least 300% on my pdf file (as well as in the model space in AutoCad. Lineweights also ONLY display in paper space once I zoom in. I need to print out at a certain dimension and am worried that the lineweights won't show.
Thank you
0 Me gusta
Responder
1.067 Vistas
8 Respuestas
Respuestas (8)
ennujozlagam
in the command prompt type LWDISPLAY set to ON. thnaks
0 Me gusta
No aplicable
Hi, thank you for your prompt response.
Lineweights is already set to ON
0 Me gusta
ennujozlagam
how about LW setting did you set? thanks
0 Me gusta
No aplicable
Show/Hide Lineweights is set at SHOW
Layers have been assigned their own lineweight
I've attached a screenshot of the page setup for the layout
0 Me gusta
No aplicable
I'm attaching too images of how the pdf looks like at default (18%) where I can kind of see the lineweights and then 100%, where no lineweights are visible and then 400% where lineweights start to show accurately. Would this have to do with the scale of my model?
0 Me gusta
ennujozlagam
try to use another pdf printer driver like BULLZIP and see if helps. thnaks
0 Me gusta
ennujozlagam
GRAPHICSCONFIG > hardware acceleration > switch to OFF and see if helps. thanks
0 Me gusta
No aplicable
Hi! Thank you for trying.. I'm still having the problem. I'll print out and see if the lineweights show
0 Me gusta
