Lineweight/Thickness AutoCAD2017
No aplicable
Line thickness doesn't change. I've already specified the line weight but the drawn lines are still default lines. I change the line thickness but still the drawn lines are default line. I can't change line weight or thickness no matter what I do.
I'm using windows 10, 64-bit.
0 Me gusta
Responder
Soluciones aceptadas (2)
4.517 Vistas
5 Respuestas
Respuestas (5)
Alfred.NESWADBA
Solución aceptada
In the video I can't see if you have activeted LWDISPLAY (to present line-weights on screen)
Line-thickness is a setting for 3D ... so the object gets something like a height. You can't see that as long as you look to the drawing from top.
The issue at the beginning of your video when you need to change the layers color to see the change to the lineweight looks like a graphic card issue.
Am I correct that your graphic card is an Intel HD....?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
schurthing
Solución aceptada
Use the LWEIGHT command and check the box "Display Lineweights".
See screen grab attache below.
EDIT: sorry @Alfred.NESWADBA already covered this.
Stefanie
crazy autocad witch since release 8 :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
No aplicable
Yes, my graphic card is an intel HD4400.
0 Me gusta
Alfred.NESWADBA
Well, that is not a graphic card that should be used when working with CAD software.
You can try different driver versions for the Intel GC, but it's always like a miracle if one driver works or not.
DId the other answers help you with the line-weight question?
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
It worked! The lines are displaying properly now as configured! Thank you very much, you are  life saver! Tell me, how can I repay you?
0 Me gusta
