Hi @Anonymous,
Welcome to the Autodesk Community!
I see that you have figured out how to create some linetypes. Your old ones will still likely work if you have all the components available in the linetype definition. If you would like to attach your .LIN file(s) i am happy to take a peek.
With your newly created .LIN file(s), I suggest keeping your custom work in a folder outside of where AutoCAD installs things. Perhaps a location such as c:\CustomAcad would work? Once you have created this folder and placed your files in it then all you have to do is go into Options>File tab and add this location to your File Support Search Path.
John Vellek
