Anuncios
LINETYPE
LINETYPE
No aplicable
Has anyone come across the issue where a certain linetype won't display as intended and instead shows up as a continuous line?
We have 3 AutoCAD licences and everything works fine for one computer, but then on the other two it's not displaying correctly.
0 Me gusta
Responder
1.314 Vistas
10 Respuestas
Respuestas (10)
ennujozlagam
have you try to switch off hardware acceleration and see if helps. install latest updates from autodesk. thanks
have you change LTSCALE value.
0 Me gusta
No aplicable
Tried all that, however still not working.
I think it might have something to do with where it's looking for the .shx file, however I can't find where in AutoCAD it is that I need to direct to my C drive
0 Me gusta
ennujozlagam
hello, is it possible you can share your file so we can check. thanks
0 Me gusta
cadffm
Very easy way: Upload dwg with one circle in model tab and one layout with one viewport.
As you say, this sample should works as expected at one of three PC.
Sebastian
0 Me gusta
No aplicable
Please find attached.
The model is TOPO BANK TOP.
When I open the drawing I only get a continuous line, when it's meant to look like the .jpg that I've also attached.
0 Me gusta
ennujozlagam
hello, just go to your layer and change the linetype. thanks
0 Me gusta
cadffm
Search for MRS_SADV04.shx on 'the one' pc,
copy this file to the similar folder on the other both pc
and if this folder isn't a support folder, add this folder as support folder -
i am sure it is added at the one pc.
(Options/Files/  first node - Searchpath for supportfiles..)
You have to learn how to set up your program, how to backup setting&templates and so on,
i can not explain it in few minutes, sorry. For now: Make sure this file is also on a safe place
outside the program and profile folders!
Note: You have to send this file to every recipient of your DWG files (with these linetypes),
it should work work by using command: ETRANSMIT with incl. the FONT option.
Sebastian
0 Me gusta
No aplicable
I can do that, but the whole point of that linetype is that it represents top of bank. Using another linetype will give the impression that line is something else
0 Me gusta
ennujozlagam
hello, you can try this go to other computer and search for acadlin.iso,  copy to your computer, load in your linetype and see if helps. thanks
0 Me gusta
s.borello
Check your annotative scale and line type scale... it's usually one or both of these things.
0 Me gusta
