Linetype with character and filled arrow left and right
No aplicable
Hello AutoCAD users,
Please would anybody be able to point me in the direction of obtaining a simple linetype with filled arrow left or right for defining a pipework direction? We have AutoCAD LT and I don't believe you can create linetypes with SHX function. When I try to use a unicode arrow in a linetype and use it, I end up with a lot of question marks, which makes me think it needs to be in an SHX file somewhere.
Any help would be greatly appreciated
Thank you,
Kind regards,
Phillip Wolstenholme
0 Me gusta
Responder
1.256 Vistas
2 Respuestas
Respuestas (2)
Kent1Cooper
Depending on how particular you are about the shape of the arrowhead, you may be able to use an ordinary text character.  For example:
*ARROWS,--------> --------> --------> --------
A,4.0,[">",ROMANS,S=1.0,R=0.0,X=-0.95237,Y=-.4285657],-1.0
That requires a Text Style in the drawing called ROMANS, with the ROMANS.shx font and without a fixed height.  The X and Y values are specific to positioning that > character in that font in relation to the line, so they would need to be different for other fonts.  You can play with the 4.0 pen-down distance and the -1.0 pen-up distance to get the spacing and gap [if any] you prefer.
Kent Cooper, AIA
0 Me gusta
dbroad
What matters is that the style in the drawing that the linetype refers to is assigned to a font that supports unicode.  This works for me, where annotative is assigned to the "arial.ttf" font.
*RIGHTARROW,--->---
A,.51,-.054786,["\U+25BA",Annotative,y=-.04801,s=.101562,u=0],-.185214,.51
You can also create a shape, filled with horizontal hatch lines.  Explode the hatch and use mkshape to create the shape. Place the shape and use it to create the linetype.
Caveat:  You should send the support files to whomever you work with (shp, shx, lin).
Here are some example looks. Top one uses unicode. Bottom uses a special shape.
Architect, Registered NC, VA, SC, & GA.
