Linetype scale in Xref
kostial.mk
kostial.mk
I have a question about linetype scale for Xrefs. I have both msltscale and psltscale set to 1, global lt scale is 1.
The drawing I am working with has lot of Xrefs, every xref scales its linetype according to the current annotation scale. But among all the Xrefs, there is one, that i would love to not scale.
Is there a way to turn off the linetype scaling for just one certain Xref? Or since mostly the drawings only have 1 viewport - to "globaly" scale linetype for just one certain Xref?
Thank you in advance!
jayhar
Linetype scale won't work with individual lines in an xref. If your lines are set to Bylayer, you can change the linetype in the sheet (parent) drawing. Check your VISRETAIN settings and also experiment with the LTSCALE and PSLTSCALE settings.
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
