Linetype Help
I recently upgraded my AutoCAD from 2019 to 2022. I noticed while working on a drawing one of my linetypes no longer looked the way it was created. It was a continuous line with empty dots/bullets, but now the line is no longer continuous and a dash is in place where an empty dot/circle was supposed to be. I tried to create a new linetype but I'm not having the best of luck with it. I also tried to add it into the file I import my linetypes but I seem to mess up since I get error messages about line definition.
Now that I learned the difference between a BUS connection & DCS connection I wanted to edit one linetype and create a new linetype. Attached is an image of the line types as they are now.
DCS connection should look like (--0--0--0--0--0--0) with empty dots/circles and no line going through the circle and the dashes are not separated.
BUS connection should look like (--0--0--0--0--) with filled in dots/circle also dashes are not separated. •
The thing is I would like to keep both dots the same size and have the fill in be the difference between them.
Any help will be appreciated.
Thank you
Irving
