Linetype generation for polylines
lovecraft
Message 1 of 10
lovecraft
Here's an odd little phenomenon that I find hard to understand.  With the variable PLINEGEN set to "1" (enabled), if I generate an ordinary polyline (any random shape comprised of pline segments) its linetype generation property is listed as "enabled".  But, after drawing a rectangle (a form of polyline, after all), its linetype generation property is listed as "disabled".  Anyone care to comment?  Whassup with this?
Thanks in advance, LC
Replies (9)
Message 2 of 10
TheCADnoob
I imagine its a feature of how the command works. If you need it to be enabled you can change your rectangle command in the cui to change the property after the rectangle after its created.
^C^C_rectang;\\.pedit;L;L;on;;
CADnoob
Message 3 of 10
TomBeauford
The RECTANG (Command) doesn't change the value of PLINEGEN but does set the rectangle polyline linetype generation to disabled automatically. I assume to make it look better.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 4 of 10
pendean
Community Legend
Community Legend
RECTANG command is not PLINE command. But POLYGON command works the way you want.
As do any LISP that use PLINE command to draw rectangles.
Odd, huh. Welcome to AutoCAD 😉
Message 5 of 10
Kent1Cooper
It's a "feature" [flaw?] of the RECTANG command specifically, which also has another similar "feature" -- it does not honor the PLINEWID setting, either.  If you have a non-zero width set for Polylines, RECTANG ignores it and draws them with zero width.
Kent Cooper, AIA
Message 6 of 10
Kent1Cooper
@pendean wrote:
RECTANG command is not PLINE command. ....  Odd, huh. Welcome to AutoCAD
Yes, it is odd, and unexpected for two reasons.  The first is the OP's issue, that what it draws is a Polyline, so one might expect the result to be a Polyline in the same vein as one drawn by other means.  The second reason is that other commands that are also not PLINE, but that result in Polylines, do honor the PLINEGEN setting [POLYGON as you mentioned, REVCLOUD, DONUT, and SKETCH when the Type option is Polyline].
Kent Cooper, AIA
Message 7 of 10
lovecraft
Thanks, Kent, for your input. Your overall knowledge is mighty impressive.
Message 8 of 10
lovecraft
Thanks again, Dean. Like Kent Cooper, your knowledge of all things ACAD is impressive.
Message 9 of 10
lovecraft
Thanks, CADnoob, for your input. Lots of useful info from all of you follow-up posters.
Message 10 of 10
lovecraft
Thanks for joining in this discussion. You and the other follow-up posters have given me food for thought.
