Lines
Lines
How do I create lines using degrees, minutes and seconds rather than grids?
Replies (10)
vinodkl
Are you talking about drawing lines with angle in degree/min/sec. Then check "UNTIS" command
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
imadHabash
i suggest to follow this video that may help . >> Click <<
Imad Habash
rkmcswain
@Anonymous - you don't have to change your units.
Suppose you want to draw a line that is at the bearing N 13° 48' 51"E and the length is 200.16 units long.
Start the LINE command, pick a point, then at the command prompt enter:
@200.16<n13d48'51"E
If you want to LIST this line (or select it and view the properties in the properties palette) and see the resulting angle listed in the same format, then yes, you will need to set AUNITS to a value of 4 (Surveyor's units).
R.K. McSwain     | CADpanacea | on twitter
Kent1Cooper
You don't say anything about Surveyor's units as some are assuming, so if you really mean simply degrees/minutes/seconds, you can use the Relative-displacement-at-angle format, for example for the second point of a Line or a Move or Copy displacement:
@31.25<54d23'14.5"
Note the use of d for degrees [angular Dimensions will show a degrees symbol, but the d is how you designate degrees in typing in angles, as with Surveyor's units].
By the way, you should probably set your angular UNITS for degrees/minutes/seconds format, but you don't actually need to -- even if they're set for decimal degrees, you can still enter angles in DMS format and it will understand.
Kent Cooper, AIA
That process didn't work. I just received the message shown in the red box as shown on the attached.
pendean
Community Legend
Community Legend
nothing attached: you have to come to the website to post files and images.
rkmcswain
@Anonymous  this is what we see.
No images are shown.
When you are editing the message, click the camera icon to attach an image inline (don't use the "attachments" below the edit box)
I have no camera icon.
pendean
Community Legend
Community Legend
It is there if you come to the website, and use the REPLY (not quickreply) button for all of us. Try it.
But first you actually have to have an image captured and saved as a PNG or JPG beforehand.
HTH
rkmcswain
@Anonymous
The exceptions to that rule are
1. You can repost images you've uploaded here in the past.
2. You can post an image that is already on the public Internet somewhere by entering the url. (For example, if your image is on imgur.com)
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
