Lines won't join like horror
No aplicable
Horrible drawinglines won't join. What is the command to do it?
I used almost everything I know. And no other forum helps me out with this.
See the attachment, real horror. The object has to be one polyline. How-to-do-it?
0 Me gusta
Responder
1.104 Vistas
6 Respuestas
Respuestas (6)
No aplicable
PEDIT JOIN
0 Me gusta
No aplicable
Haha. Yess... well, this was just the first part.
See the whole part below. How to do it fast? Which command can fix this?
0 Me gusta
Patchy
3 seconds.
Pedit, multiple, join.
No aplicable
Still some polylines aren't 'poly-ed'. Why is this happening?
And hatching behaves also very strange. See file.
And thank you for your previous answer.
0 Me gusta
Patchy
Click on the polyline, go to Properties, change this to Yes, that will close it.
0 Me gusta
Kent1Cooper
And hatching behaves also very strange. ....
PEDIT and the Join option works for me [Acad2016] in the right part.  But in case this affects different versions differently, I find that the longer Polyline of that outline [the all-but-two-segements part] starts off with three vertices at the same place.  Try eliminating those coincident vertices [you can Explode the Polyline and Erase the zero-length resulting Lines and PEDIT/Join it all back together, or use PEDIT and its Edit-vertex/Straighten option to make it go from the start to the other end of that first real segment], and see whether it then works for you.
Also, Hatching behaves normally for me, with or without Joining that one outline into a single Polyline.
Kent Cooper, AIA
0 Me gusta
