Lines showing up on page
Message 1 of 10
These Lines are showing up on my screen. If I type REGEN they come back in different directions. If I zoom in or out they also change. They do not show up when printing. How do I get rid of them.
Replies (9)
Message 2 of 10
Darin.Green
WBLOCK the contents to a new drawing to see if the issue persists. If so, the geometry needs to be inspected. If the issue doesn't exists after the wblock, then I would recommend continuing with the new file as your existing file could be corrupted.
If this information was helpful, please consider using the Accept Solution
Message 3 of 10
imadHabash
I suggest to Diasable your hardware acceleration from 3Dconfig command.
Imad Habash
Message 4 of 10
pendean
Community Legend
Community Legend
Turn off LINESMOOTHING and LINEFADING variables: your video card is choking under AutoCAD.
Message 5 of 10
TheCADnoob
The looks exactly like hardware accleration issue as @imadHabash and @pendean indicated. Click on this critter to make their suggested changes.
CADnoob
Message 6 of 10
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
If turning off Smooth Lines (GRAPHICSCONFIG) doesn't work, try setting PDMODE to 0. It is possible that these lines are Nodes (points).
John Vellek
Message 7 of 10
fixed it, thank you very much
Message 8 of 10
imadHabash
how great to hear that...Smiley Happy
Imad Habash
Message 9 of 10
I did not try this yet but I will. Would you say that this option would save me from having to turn off acceleration?
Message 10 of 10
TheCADnoob
If you are wanting to leave acceleration on I have seen some have luck changing from 2D wireframe to wireframe and it got rid of the lines for them but this of course is not a solution but just a work around and is not recommended.
CADnoob
