Lines plotting in different shades but are on same layer with the same properties.
Nelly_KES
Message 1 of 13
Nelly_KES
Replies (12)
Message 2 of 13
pendean
Community Legend
Community Legend
Curious why "plines" are showing an AREA listing, are some of those closed shapes or something else
Message 3 of 13
cadffm
Because AREA is a property of Polylines,
and if you have a pline with more than 2 vertex and not all are in one straight, you will have an area >0
@Nelly_KES
share your PDF (and DWG, if possible), tell what PFD viewer you are using.
I guess some lines are ortho and some not.
Sebastian
Message 4 of 13
Nelly_KES
Hi.
Yes, the lines are different lengths, why would that affect the shades they print into PDF?
If I adjust the length the lines get longer or shorter. I want the length to stay as is.
Message 5 of 13
pendean
Community Legend
Community Legend
That's exactly my point: look at the screenshots, no second vertices.
Message 6 of 13
Nelly_KES
I've attached the files. I am working on adjusting the area and length but still no luck.
Message 7 of 13
cadffm
Try another PDF-Viewer or search the setting in your current one
here is a screenshot of my
Sebastian
Message 8 of 13
Nelly_KES
Thank you, this worked. I appreciate your help 🙂
Message 9 of 13
Kent1Cooper
@pendean wrote:
Because AREA is a property of Polylines, and if you have a pline with more than 2 vertex and not all are in one straight, you will have an area >0
The two in the image that disappear off the bottom might be ends of the same Polyline, connected down below.  They must be, with Properties showing 5 Polylines selected.  That would explain the areas not all being zero.  But in any case, it seems irrelevant to the question of different plotted appearance, if they're all the same object type on the same Layer with the same properties other than length and area.  It doesn't make sense to me that a different PDF viewer would show differently, either, but if it does....
Kent Cooper, AIA
Message 10 of 13
cadffm
>>"The two in the image"
The DWG is available now and it is the case.
>>"It doesn't make sense to me"
Another Viewer OR another setting - also another Zoomlevel in a PDF Viewer can show the content differently.
Linesmooting or for text "clear Text" or similar settings can force i.
In this case here and with adobe software it is "thin lines thicker" .
"Thin" are lines what in horizontal or vertikel direction just one (or two?) pixel width
 displaying (<- displaying! so if you zoom bigger, all lines are displaying well)
Sebastian
Message 11 of 13
pendean
Community Legend
Community Legend
Where?
Message 12 of 13
pendean
Community Legend
Community Legend
It's not a solution, just something every Adobe Acrobat Reader/Editor user needs to do to overcome Adobe's need to make their bloatware more nimble on user PCs. This is what I have the display settings at for all of our staff just in case they skip over the better PDF Editors they also have access to
Message 13 of 13
cadffm
2h20min ago,
looks like TO removed the file/post then
Quote: "I've attached the files. I am working on adjusting the area and length but still no luck."
Sebastian
