Anuncios
Lines and polylines joining automatically while drawn separately
No aplicable
Hi All,
As said in the title, lines and polylines are connecting automatically. I've tried to add an example of the problem: https://imgur.com/a/0qlKBpi. The square is a polyline, the line within the square is just a line drawn separately from the square. If I move the vertex of the line the square moves along as well. While moving the vertex I made sure I only selected the line I wanted to move. Only the command explode seems to work, but I don't want to explode my drawings for obvious reasons.
I couldn't find the solution on how to turn the option off on any forum. So I hope you can help!
I'm using AutoCAD 2011
0 Me gusta
Responder
Soluciones aceptadas (2)
2.812 Vistas
6 Respuestas
Respuestas (6)
imadHabash
your attached images didn't help , would you please attached here your CAD dwg sample , for testing ?
Imad Habash
No aplicable
Thanks for the quick response! I've attached a test file.
imadHabash
Solución aceptada
your line is constrained use DELCON  [DELCONSTRAINT] command to solve your issue .
Imad Habash
No aplicable
That works, thanks a lot!
imadHabash
Solución aceptada
also make sure that CONSTRAINTINFER = 0 ( zero ) . >> Click <<
Imad Habash
imadHabash
Sorry ... it's important also to know that from CONSTRAINTSETTINGS command you can tick those options ( see below image ) .
Imad Habash
0 Me gusta
