Lines and Objects Hidden But Appear During Pan Command
clippincott-CL
Message 1 of 9
clippincott-CL
I have received an Architectural CAD file to use as a background to my drawing and it is behaving strangely.  I know the Architect uses BIM software called ArchiCAD, so this CAD file was exported from their BIM model.
I have discovered that some of the objects in the drawing are being concealed by something, I don't know what.  It behaves like a WIPEOUT but I can't fine any wipeouts.  I have wipeout frames set to ON.  The only way I know this is happening is the objects become visible during the PAN command.  When I move the drawing around, I can see lines appear all over the drawing where there hadn't been any visible before.
I have attached the drawing file.  Does anyone know what is causing this?
Thanks in advance for any assistance offered.
Replies (8)
Message 2 of 9
imadHabash
as below attached image this is exactly what i see and there is nothing notice when pan the drawing. please try to open the attached CAD file and see if any changes.
Imad Habash
Message 3 of 9
clippincott-CL
imadhabash,
Unless you made some changes to the drawing I attached, the drawing you posted should be identical to the drawing I posted.  I opened yours and it looked the same to me, still hidden objects only appearing when I pan.
Message 4 of 9
imadHabash
>> I opened yours and it looked the same to me <<
it's the same ... i just clean your original drawing . Now is it easy to make a screenshot OR screen-cast that show this invisible items ?  also does the image that i attache it in my previous post appeared correct and match what you see on your screen ?
Imad Habash
Message 5 of 9
clippincott-CL
imadhabash,
The drawing you posted looks exactly the same as the drawing I posted.  I don't know what you did to "clean" the original drawing but it didn't solve the problem.
Message 6 of 9
Alfred.NESWADBA
When I use PAN command or middle mouse button I don't see anything more than without PAN, no new objects are shown.
So that brings me to some questions:
  • which type of AutoCAD do you use
  • which version of AutoCAD do you use
  • which service packs are installed for your AutoCAD
  • have you tried to turn off hardware acceleration (command _GRAPHICSCONFIG) to see if the same happens without hw-acc.
  • which graphic card do you have installed
  • which operating system has your workstation installed
As I can't see any new lines I'm not sure to have my eyes at the correct position to see that behavior, could you be so kind to use Autodesk Screencast (>>>free to download<<<) and record the screen + show us that the link to that recording ... so we can see what you see and concentrate to do exactly the same steps.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 7 of 9
clippincott-CL
Alfred,
I am using AutoCAD 2016 (via Building Design Suite) with all service packs installed on a Windows 7 system.  Hardware acceleration is turned off and I think my graphics card is an ATI Tadeon HD 4800 Series.
Sorry, but I don't have time to make a recording of my actions working in the drawing.  I guess this is not as simple of a fix as I thought it would be.  But your questions made me think of some avenues to research, i.e. object enablers.
Thanks for your assistance.
Message 8 of 9
Alfred.NESWADBA
can you please start 2 commands and upload screenshots from both dialogs?
Commands _GRAPHICSCONFIG as well as _ABOUT.
From what I know there are no object enablers necessary for your drawing as no proxies are inside the file.
It's just 5 minutes, but it's up to you 😉
One idea: open that file, create a new file, use command _COPYBASE and _PASTECLIP to copy the existing geometry to the new drawing (IMPORTANT: please use window or crossing selection for the objects to be copied, not _ALL from command line)) ... does PAN then again show mystic lines?
- alfred -
PS: there are 100 wipeouts, maybe you can select them (command _QSELECT) and delete them.
Alfred NESWADBA
Message 9 of 9
clippincott-CL
It was the wipeouts.  Now that I've deleted them, the lines that were hidden are visible all of the time.  Thanks, Alfred.
