Lines and Arcs do not connect properly when I plot
Message 1 of 8
I fillet some of my rectangles and have some arcs connected to lines but when I plot, they don't show up as connected. I have tried to make the loose lines and arcs into a polyline but it is still not smooth when I plot.
john.vellek has embedded your image(s) for clarity
Replies (7)
Message 2 of 8
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 Is it possible to share your drawing file or even a part of it?  I would like to verify that the lines and arcs actually do "connect" at the same points.
John Vellek
Message 3 of 8
Hello! Thanks for replying, but I've managed to fix it by increasing the dpi in the plotting properties 🙂
Message 4 of 8
john.vellek
hi @Anonymous,
I am glad to hear that it worked. I’ve just accepted your response  as a solution so that others can benefit from the information.
In the future, please click on the ‘Accept as Solution’ button if/when relevant. Please feel free to let me know if you have any questions or concerns!
John Vellek
Message 5 of 8
Changing the DPI didn't actually solve anything, so my lines are still not connected. I attached my dwg.
Message 6 of 8
john.vellek
Hi @Anonymous,
I started looking at your drawing file.  I notice that many of the corners are constructed of plines which is a bit unusual rather than just using a FILLET command to make a nice curved corner that will connect to the straight sides.
I also noticed that much of this is just geometry rather than being blocks.  The geometry is also not set to bylayer.
Ideally, you would create a block on layer 0 with properties set to Bylayer for each typical piece and then insert the block on the correct layer that already has a color assigned to it.  I have done this for some of the chairs and for the sink.
Please take a look at my version and let me know if you have additional questions.
John Vellek
Message 7 of 8
It's a lot better, thank you! But when I make the lineweight thinner, the lines are more obviously unconnected.
Message 8 of 8
john.vellek
Hi @Anonymous,
Please take a look at the attached file. I did clean up the CAFECHAIR block a bit more as it was not even perfectly symmetrical. At any rate, once I cleaned it up, I then used the AutoCAD PDF driver and set the vector resolution to 4800.
This seemed to give me a better quality plot.
John Vellek
