08:30 AM
I am using AutoCAD 2014. I changed my DIMSCALE and AMSYMSCALE from .5 to 1. However, only my radii dimensions and balloons come out correct but the linear dimensions do not. They stay at .5. I checked the STYLE setting and the text height is set to 0.
In the Dimension style, my overall scale is 1.00. But when I check each dimension's properties, my radius dim overall scale is 1.00 but my linear dimension overall scale is .50. How do I make them the same for all other dimensions?
Link copied
