Line width
maf6677
Line width
maf6677
Hello Why is there a reason to use half width for poly widths?
0 Me gusta
Responder
Soluciones aceptadas (2)
1.265 Vistas
13 Respuestas
Respuestas (13)
MikeKovacik4928
Thanks!!
In all my 20 years of using autocad,
I have never used that.
It is perfect for making arrowheads.
I'm sure there must be other uses for it as well.
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
maf6677
Thank you My question is why we insert half the width and instead use the total width we are considering.
0 Me gusta
imadHabash
Hi and Welcome to AutoCAD Forum,
>> Why is there a reason to use half width for poly widths? <<
it's just an option to use . it's used to specify the width from the center of a wide segment to an edge and the value will also save in WIDTH option .
Imad Habash
maf6677
thanks for your answer So there is no particular reason for it? Because it seems to make it harder, especially since the decimal number is ours.
0 Me gusta
imadHabash
it's the same when you draw Circles with Radius or Diameter inputs.
Imad Habash
0 Me gusta
maf6677
Is there a specific application in the industry?
If you have an example, please.
0 Me gusta
Vinayv4v
Sometimes I use it to create arrow heads using halfwidth.
Halfwidth- Starting width - 10, Ending width - 0.
Cheers,
Vinay Vijayakumaran
0 Me gusta
imadHabash
Yes that's right ... even the same with Width option .
Imad Habash
0 Me gusta
imadHabash
>> Is there a specific application in the industry? <<
sorry ... specific application for what ?
Imad Habash
0 Me gusta
maf6677
Consider the width we are considering is 235.718. Why should I enter half of it? If we can easily enter that number itself.
0 Me gusta
maf6677
I know how to use it. I just want to know the reason for this.
0 Me gusta
Alfred.NESWADBA
Solución aceptada
Not sure if you understood that "Halfwidth" is one of the options, you don't need to use it if you want to input the full width then use option "Width".
There are a lot of options available that one never need while some other people might need it. Don't care about it if your workflow does not need a "Halfwidth" option.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
Kent1Cooper
Solución aceptada
In my opinion, the principal use for that option is that it makes picking the width on-screen  (rather than typing in a value) easier.  Calling for the Half-width option gives a rubber-band off the latest vertex location [which is at the mid-line  of the Polyline path], and from there you can pick what will be the location on the edge  of the resulting overall width.  Sometimes that is determined by something you can Snap to, so you don't need to know the actual value, etc.
Kent Cooper, AIA
