Announcements
Line snap at 45 degrees
jbaflyer
jbaflyer
Basic question for a very long time acad user.
Per the attached screen shot I want the green line to snap to the yellow line at a 45 degree intersection.
If I am on osnap, 45 setting, no issue but when I hover the line, I cannot snap to it at a 45.
I am not snaping to a midpoint, endpoint just somewhere along that yellow line.
What I usually do is draw a pline and overshoot then redraw and erase the guideline. Another option is to extend.
I am wondering if there is some setting, I did not see in holding the shift-right click anything.
Just curious if there is a short cut as I can find nothing.
Thanks for any help.
imadHabash
If i understand your question... you can use (int of) while you are in command.so if you need to draw a line from green line extension to meet the yellow one;just type ( int ) for first point then select green line then go to the yellow one and you will see the (x) appear.(see attached image)
Command:  LINE
Specify first point: int of and
Imad Habash
elshawadfy
Hi @jbaflyer,
If you want to be able to start drawing from a point that lies on a 45 degree line from another point, you need tho do the following:
1- Make sure Object Snap is enabled (can be toggled by pressing f3)
2- Make sure Object Snap Tracking is enabled (can be toggled by pressing f11)
3- Make sure Object tracking is on (can be toggled by pressing f10)
4- in object tracking make sure you added 45 angle and enabled tracking with all tracking angles..
See the pictures:
Best of luck 🙂
Alfred.NESWADBA
look to that, I guess the is what you are looking for
Polar tracking by 45° starting from the startpoint of the line (not the point you want to stretch).
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
jbaflyer
All, thank you.  I had been out of town, and after figuring this out, it will make my like infinitely easier.  🙂  Thank you for posting the solution.
