Line problem when doing isometric drafting
No aplicable
When i want to draw isometric projection using autocad 2017, i switch to isometric drafting but the line still in x-y plane it doesnt give me a slanted line instead. How am i going to solve this problem?
0 Me gusta
Responder
Soluciones aceptadas (1)
3.203 Vistas
5 Respuestas
Respuestas (5)
imadHabash
use ISODRAFT command.you can use it from command line and from below status bar. see attached image.
Imad Habash
0 Me gusta
No aplicable
i have switch on the isometric drafting already. Let me show you what the line problem is.6eab6be9-5df9-4c7b-8d5a-333d30021c85.jpg
0 Me gusta
imadHabash
from your picture this behavior happened because Polar Tracking (F10) is ON and because of it your cursor catch the horizontal line.also you have first to turn ON ortho (F8). try toggle between F8 and F10 and you will notice the different.
Imad Habash
0 Me gusta
No aplicable
Sorry but i have tried toggle btween F8 and F10. When i switch off F10, i lost my indicator to know which is 30 degree or 120 degree and my ellipse also seem weird after drawnScreenshot (10).png
0 Me gusta
imadHabash
Solución aceptada
HI,
>> When i switch off F10, i lost my indicator to know which is 30 degree or 120 degree <<
you can turn it ON,there is no problem. the purpose was to discover the difference not more.also there is no need to know the angle since there is just three isoplane (Left,Top and Right).
>> and my ellipse also seem weird after drawn <<
when you active ellipse command use Isocircle option.
Command: ELLIPSE
Specify axis endpoint of ellipse or [Arc/Center/Isocircle]:
Q: does your main issue solved or not? :cara_con_una_leve_sonrisa:
Good Luck..
Imad Habash
0 Me gusta
