AutoCAD Forum
Line is not connecting to a circle's quadrant
12 REPLIES 12
Message 1 of 13
1295 Views, 12 Replies
i have been snapping a line to a circle' s quadrant but it is not closing. how can i solve this?
12 REPLIES 12
Message 2 of 13
imadHabash
You may need to check your OSNAP modes and make sure that you select your needed ones . it will be great if you can post an image for your issue ?
Imad Habash
Message 3 of 13
in reply to: imadHabash
Here's the photo. I made a mistake. it was supposed to be an isocircle's quadrant.
Message 4 of 13
vinodkl
Hi @Anonymous
I feel the line is snapped to the quadrant, but it looks like that is because of the smoothness of the iso circle. Type in the command "VIEWRES" and set it to "5000" and see if that makes any difference 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 5 of 13
imadHabash
Try also Regenall command .
Imad Habash
Message 6 of 13
in reply to: vinodkl
i already did it and i even set it to 10000. it actually worked except on the isocircle shown in the image.
Message 7 of 13
it improved the line's quality but it still failed to connect it
Message 8 of 13
imadHabash
would you post here your CAD dwg file ( just the part we need to check ) , for testing ?
Imad Habash
Message 9 of 13
sure. here you go
Message 10 of 13
vinodkl
Edited: Ignore this.
Message 11 of 13
vinodkl
Looks good on my end. See snapshot below.
Type in the command "3DCONFIG" and see if its turned "on" and check if the "smooth line display" is enabled.
Message 12 of 13
it is actually turned on. im surprised that it turned out okay on your end, but i dont know why my display screen shows otherwise
Message 13 of 13
pendean
Post a screenshot of your ABOUT and GRAPHICSCONFIG commands pop-ups please.
