Line Have Different Lenght Between Dimension and on Layout in Autocad 2D
Halo everyone, i have a problem with line (L) when I create a line and put the dimension/lenght, the line i create not seem like right. for example, my 3metres line have longer than my 4 metres line. when i check on properties, the short one says 4metres but in my workplane it shorter than the 3metres line. anyone can help me ? and maybe can explaind what happen on my work. thankyou guys
Valentin_CAD
The issue may be a "z" value on the line. See sample of two lines dimensioned, but the length of the bottom one shows a longer length in the properties.  The issue here is the "Z" value.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
imadHabash
Can we have a look to those two lines please ? put a CAD dwg sample here to check it for you .
Imad Habash
