Line drawing with isometric
No aplicable
I have some problems when drawing a line, it doesn't want me to draw them unless they have a length that is a multiple of 17.32. And this is for when i want to draw them horizontally or vertically (no angle).
0 Me gusta
Responder
Soluciones aceptadas (1)
1.564 Vistas
5 Respuestas
Respuestas (5)
JDMather
Can you post example file that exhibits this behavior?
Are you using Grid and Snap? (don't)
0 Me gusta
No aplicable
If Grid and Snap means using a 2D point grid, yes.
Included is my file.
I want to make a line from the center of the top circle.
0 Me gusta
No aplicable
It's ok. I've found what's wrong. I needed to press F9.
MAybe Autodesk should consider making a table for the function keys in French with explanations of what happens when pressing the key.
0 Me gusta
Kent1Cooper
What you're seeing in the horizontal direction is the distance to the next isometric grid point when the Snap value is 10 [= 2 x 10 x the cosine of 30 degrees].  [Look closesly for the white grid points.  I'm not sure why it's giving me 17.31 in the image -- it really ought to round to 17.32.]  But you should still be able to draw vertical Lines at multiples of 10 units rather than 17.3whatever, with Snap on in Isometric mode.  You can also press F5 to cycle between the "planes" of isometric drawing, if that helps you do what you want ["top" in the image"].
But also, without turning Snap off with F9, you should be able to "aim" with the cursor location in whatever direction you want and type in a value for the distance, not limiting yourself to positions that the cursor will Snap to.  If drawing on the "top" isometric plane, you would need to have Ortho turned off [F8] to draw a vertical line, but Snap locations can "lock" you into a vertical direction.
Kent Cooper, AIA
0 Me gusta
JDMather
Solución aceptada
Probably lots of free sources on the internet but you might try >>this << site.
