Line Command Not working
w213806693
Community Visitor
w213806693
Community Visitor
Community Visitor
I am using a template that I created.  Last night I was able to draw lines just fine, but today I cannot see any lines when using the line command. It doesn't draw anything. The line command does not work.  When moving my mouse you can see that it is measuring the dimensions, but nothing shows on the screen.  It is completely blank.  Additionally, the grid lines will not appear at all.  If I start a new drawing, I can use the LINE command just fine and my grid lines appear.
I need to be able to use the template that I created.  It has all the layers I need for my project.  Hoping someone can help me resolve this issue.  Thanks!
Kent1Cooper
Is the current Layer turned off?  You probably wouldn't do that intentionally, but it is possible.
Does pressing the F7 key turn the grid on?
Kent Cooper, AIA
Alfred.NESWADBA
This looks like you are not looking vertical to the current UCS-plane.
Try this (in case you are working 2D):
Command _UCS with option _WORLD ... then command _PLAN with option _CURRENT
Does the grid now show up, can you now draw (and see) lines?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
vinodkl
Hi @w213806693
Are you sure it's line? Or is it a polyline? If it's a polyline then you would see this happening when polyline width is set higher than zero. Type in the command "plinewid" and set it to "0". Also type in the command "Dragmode" and see if it's set to "auto" and see if that helps🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
al2163000031
usally F2 brings my command line back from wherever it was lost
