The panel behind the matress is 1.9mm thin, is that steel? Otherwise it would not work in reality.
The distance between the lights to the back plank is 0.6mm, from what I know the distance is too small for lights today.
Then there is the limit for rendering calculations for performance reasons. So materials which should not be transparent should have a minimal thickness, otherwise the light shines through that. Imagine the light is calculated by ray length, the smaller the steps you have to calculate, the more time is needed. The larger the steps, the faster is the rendering ... but in case the steps are to big some geometry objects are not seen by the calculation.
BUT ... all what I have wrote in the last 2 sentences is close to bull-****, because the calculation with current render systems works very different, but it was more easy to make it understandable (hopefully).
At least: look to your units, they are set to Millimeter. measuring your bed it results in 200mm long ==> wrong, I guess you meant 200cm, so use command _UNITS, set the linear units to Zentimeter ... and now try the rendering again, surprise, surprise 😉
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
