Light lines
Light lines
hansfordCom
Message 1 of 8
Light lines
hansfordCom
So I'm trying to save a dwg file to a pdf but sometime not all the lines show.  Some lines and text show but not all of it does anyone.
this an example.  Some of the lines are dim and some are dark enough to see.
Replies (7)
Message 2 of 8
imadHabash
does this happens always and in every CAD dwg or just here ?
we need your CAD dwg and your ctb files for testing ?
Imad Habash
Message 3 of 8
pendean
Community Legend
Community Legend
If you zoom in, do those light lines suddenly appear just fine?
Or in your DWG file are those lines set to a NOPLOT layer or you are using RGB white color 255,255,255 (which do not print)?
Message 4 of 8
hansfordCom
I think when i zoom in the line appear a bit better.
And I check I have the all on a standard 0 layer and all colors are by layer.  So idk what it is?
Message 5 of 8
hansfordCom
This seems like all my cad files every time I try to save it as a pdf. For reason when I zoom in the lines are fine but far back it looks like some lines fade.  I send you one sheet for reason.
Message 6 of 8
imadHabash
as you can see in below attachment .. there is no problem when i plot your file to pdf by DWG To PDF.pc3
Imad Habash
Message 7 of 8
hansfordCom
Ok but what did you do to make it work?
Message 8 of 8
imadHabash
Nothing ... just plot !! how about changing your plotter type or make another one .
Imad Habash
