>> I want the dark lines to be forward (the darker line on
>> the right) and have the light line to the back
Which helps to define it, but I can't tell you now why this does not work as I don't have the drawing.
From the screenshots I can't select an object and see if that is a line, a polyline, a block, on the same layers or different layers, ....
The strange thing is more that your coworker can plot that with the correct draworder (or does he have a different CTB and plots different colors maybe) ... questions over questions ...
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
