left leader is differnet then a right leader.
gerrylobley
gerrylobley
I am using mleader standard and when I have the text on the left it gets underlined and on the right its how I would like it and the leader stops in the middle of the text. See attached png
TomBeauford
In your Multileader Style [Content] tab you must have the "Always left justify" box checked.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Cannot-restore-aut....
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
user181
Use MLEADERSTYLE command and edit your leader style and on the content tab at the bottom is the left and right attachment settings
gerrylobley
Thanks a ton. For some reason I thought that those pull down fields were not used when Horizontal Connections was selected. Thanks again.
