Leder on circle
Leder on circle
ttesfaye2
Leder on circle
ttesfaye2
Community Visitor
Community Visitor
Hi guys, I want to make a leader to a which points   twoards the bodrt of the circle. But every time I made one it starts from the ccenter. How can I fix that? Thank you
Tomislav.Golubovic
Like this?
imadHabash
Hi and Welcome to AutoCAD Forum,
I think that we still need more clarification for your issue.
As much as i understand ... you may need to check your OSNAP selected options. Make sure that Quadrant snap is activated.
Imad Habash
Valentin_CAD
@ttesfaye2 ,
Just uncheck the "Draw dim line between ext lines" in your Dimension Style.
Note there is also an option to select NONE for the center mark.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
