Learning Hatch pattern Confuse
Hi All
i am Learning to create custom hatch pattern. and i try to understand AutoCAD hatch pattern but i don't understand these 2 hatch
as i Understand Hatch pattern is  (Angle , OrgX, OrgY, DeltaX, DeltaY, +00(Line) 0(dot) and -000 (is Gap);
so in the Angle Hatch pattern there is no DeltaX in the second 90 deg line. how it create  Line in the x offset?
*ANGLE, Angle steel
0, 0,0, 0,.275, .2,-.075
90, 0,0, 0,.275, .2,-.075
And Second is
Rename of Solid "this does not work as AutoCAD solid hatch.. Why?
*ReSolid, ReSolid
45, 0,0, 0,.125
Thanks in Advance.
Kent1Cooper
*ANGLE, Angle steel
And Second is
*ReSolid, ReSolid
45, 0,0, 0,.125
The first one is because of something that's often confusing -- while the X and Y coordinates of the origin point for a lineset [in this case the 0,0 entries in both linesets] is in relation to "World" orientation, the X and Y offsets [in this case the 0,.275 entries in both linesets] are in relation to the angle at the beginning of the definition line, and not to the "World" orientation.  So for a 90-degree lineset, "X" is upward [in that 90-degree direction] rather than to the right, and in relation to that orientation, there is no X offset for that lineset.
As to the second one, I believe the SOLID definition is a kind of "stand-in," and AutoCAD really does it differently somehow based on the SOLID name specifically, so giving that same definition line a different name will give you the "literal" result of that definition.  But I do have to ask: why would you want to use a SOLID pattern under a different name?
Kent Cooper, AIA
hi Kent Cooper
Thanks for reply.
so for the first one.. if angle rotate, it mean Delta X and Delta Y also Rotate.
like 45, 0,0,   0.5,0.5,   0.5,-0.5
so when it draw it will rotate Delta X and Delta Y from the 0,0 . is that correct? is is apply to all hatch pattern? or just in some case.
because i check and i did not get .1767766 in any dimension in this hatch. is am i missing any thing  or  am i  not understanding some thing.
*FLEX, Flexible material
0, 0,0, 0,.25, .25,-.25
45, .25,0, .176776695296,.176776695296, .0625,-.2285533906
for the solid i am just testing as i mansion i am learning to create hatch pattern.
Kent1Cooper
@Anonymous wrote:
.... i did not get .1767766 in any dimension in this hatch. is am i missing any thing  or  am i  not understanding some thing.
Kent Cooper, AIA
oh..... i see..
so it mean that delta x and delta y also rotate as per angle....
Thanks for clear me.
ambrosl
I will try to explain to you what is happening in a hatch pattern.
angle, x-origin,y-origin, delta-x,delta-y, dash-1,dash-2, …
angle, - Specifies the angle in which the line segment should be drawn based on the current UCS; think of this as rotating the UCS around the specified origin and that the line segment is always drawn along the X-axis
x-origin,y-origin, - Specifies the point origin in which the line segment should be started from
delta-x,delta-y, - Specifies an offset from the origin
dash-1,dash-2, - Specifies the dash gap sequence in which the line segment should be drawn
Lee Ambrosius
Senior Principal Content Experience Designer
For additional help, check out the AutoCAD Developer Documentation
Hi Lee. thanks for reply...
Now i understand..
Thanks Again
