Leader Text not displaying
Hi, I'm trying to create some leaders to relate to various layers in my drawings. I'm using a circular block multi leader style however the text is not displaying. If I change the block style to any of the others slot, box, hexagon or triangle the text in the block displays however if i choose the circle or detailed callout the text only displays temporarily if click one of the blue squares as if it move the positioning of the leader, as soon as I reposition it the text no longer displays. I think it's going to be some kind of setting in the layers as this worked perfectly for me on friday. Any help would be greatly appreciated
imadHabash
Hi and welcome to AutoDesk community,
Would you post a sample drawing with your mentioned leader?
Imad Habash
It could be that the text height is too small. The text is visible while you're still typing, but as soon as you finish it goes back to it's default size and the scale could be too small for what you're using in that drawing, so it "disappears". It happened to me once.
