Anuncios
Leader arrow won't move when repositioning note
No aplicable
Leader created using QLEADER.  Moving the leader will move everything but the arrowhead.  It seems to be locked in place.  Even moving the entire drawing has no effect.  Solutions?
0 Me gusta
Responder
3.343 Vistas
17 Respuestas
Respuestas (17)
dennis
I can't duplicate what you describe.  Could you post an example DWG?
0 Me gusta
imadHabash
Try to do :
- Disable Hardware acceleration.
- Download latest Service pack & Hotfixes.
Imad Habash
0 Me gusta
No aplicable
2016-08-11 08_55_32-Autodesk AutoCAD 2017 - [Drawing1.dwg].png2016-08-11 09_02_25-Autodesk AutoCAD 2017 - [Drawing1.dwg].png
0 Me gusta
imadHabash
This is exploded Qleader,isn't it?
Imad Habash
0 Me gusta
No aplicable
No sir.  The command isn't completed yet.  If it were exploded the arrow would move.  The arrow seems to be locked into that spot and cannot move.  I've moved all of the associated geometry and still nothing.
I think I may reload the software.  This is something I've never seen before.
0 Me gusta
imadHabash
post here your case as CAD drawing.
Imad Habash
0 Me gusta
No aplicable
Help is appreciated, but I'm in the process of reloading the software. My schedule doesn't allow me much time to troubleshoot problems that can be fixed with a fresh install and setting import. If it continues after the install I'll do as asked.
0 Me gusta
pendean
Community Legend
Community Legend
Your leader arrow is defined on a layer you have locked most likely: is layer 0 (zero) turned on/thawed/unlocked?
No aplicable
Hi, I had the same problem with this leader. Everything in unlocked & thawed but still its seem to be locked in place. I hope autodesk could fix this.Thanks
0 Me gusta
john.vellek
Hi @Anonymous,
I believe there is something corrupt in your drawing that is causing this behavior. I can move the leader line and the Dot remains in its original position. Then I run Audit and the Dot moves to the new location.
John Vellek
0 Me gusta
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
0 Me gusta
No aplicable
Hi, @john.vellek,
I tried running an audit but the problem remains the same. I agree with you. there might be a corrupt in the file. Thank you very much anyway.
0 Me gusta
RobDraw
Wait, you have just enough time to ask for help but you don't have time to help those that want to help you? Good luck!
Doing a fresh install is a waste of time unless you are completely at a loss. You have not learned anything by doing that and won't know how to fix or prevent it from happening again. It is probably a simple fix that will save you time in the future because you won't have to lose production time when you are doing the fresh install.
"An ounce of prevention is worth a pound of cure."
Find the time for troubleshooting.
Rob
David_Robison
Five years later, posting a fix because I just ran into this same problem.
My fix: type SHADMODE at the command line, then 2. It was set to wireframe accidentally.
The error happens on leaders that use a custom block for the arrowhead. Leaders with built-in arrowheads work fine. This error and fix worked in AutoCAD 2021.
No aplicable
Thank you very much. It worked!!!
0 Me gusta
remoF9FGR
Observer
Observer
I had the same problem and that solution with changing the shademode solved the issue. Thank you very much for your help.
0 Me gusta
johnfinnell64
7-1/2 years later, thank you David Robison.  I've had this issue for years, SHADEMODE fixed it.  With so many miniscule drawing functions it's extremely frustrating not knowing these arbitrary settings.
0 Me gusta
