Anuncios
Layout measure different for lenght and area (AutoCAD 2016)
No aplicable
I'm using AutoCAD 2016. I have a problem with measuring in Layout. When I use "Measure" tool for distance, it is shown 40 (as mm on paper) and after measuring it' 2000 (real distance in mm). When I use "Measure" tool for area, it always measures area on paper. In previous AutoCAD I used area measurement in same case and in worked perfectly - real area in mm was shown. How can I change measuring the real vs. paper distance?
Drawing in model is in scale 1:1, then layout in 1:50.
Drawing units are everywhere set to mm.
Page setup is in mm.
-DWGUNITS <3> (mm)
DIMASSOC <2> (0,1 with no change)
Thanks for response.
0 Me gusta
Responder
828 Vistas
5 Respuestas
Respuestas (5)
pendean
Community Legend
Community Legend
Post the DWG file here, and put notes in there so we can replicate.
0 Me gusta
No aplicable
I noticed your answer just now. The dwg is attached.
Thank you very much for your time.
0 Me gusta
No aplicable
How do you solved the problem ?? I have the same situation and I cannot measure the distance in the layout.
0 Me gusta
No aplicable
I had this problem just in one file. I made a new file, copy-paste everything from one to another and the problem dissapeared. I assume, that the first file was somehow damaged. New one works just fine.
0 Me gusta
parkr4st
the area in the table is correct in square meters.  how do the table get set up/ generated?  division by 1,000,000?
0 Me gusta
