Layout list after 2016
Darwin33
Message 1 of 8
Darwin33
I found layout list very useful until it dissapear on versions after 2016. I wonder why that this happen. Is there any alternative?
Replies (7)
Message 2 of 8
jayhar
Hi @Darwin33
Do you mean, layout tabs are not showing or missing in AutoCAD ????
Command LAYOUTTAB <1>
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 3 of 8
Darwin33
Not, is not that question. The question is how to list all the names of the layouts in a txt file, so I can make a list of my all plans in a project.
Message 4 of 8
S.Faris
You can copy and paste this macro in the commandline " (foreach i (layoutlist)(print i)) " and then copy the output to a text file
Source
Or you can use this lisp method : Listing the layout names
SALMANUL FARIS
Message 5 of 8
Alfred.NESWADBA
Most probably: you also used a tool that did it for you, because AutoCAD 2015 and older are not having a command like layoutlist too, so nothing changed with 2016 😉
If you are referring to command -LAYOUT and option ? ... which creates a list of layouts, well, this works with versions 2016 and newer too.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 6 of 8
florian.vivaldi
-DISPOSITION out off order on ACAD2022 😞
Message 7 of 8
cadffm
@florian.vivaldi  What are you trying to tell us?
Sebastian
Message 8 of 8
Kent1Cooper
If that is the French [and/or possibly some other language(s)] command name equivalent to English -LAYOUT, does it work if you force it to use the English command name, using the underscore prefix that makes it work in AutoCAD for any language?
_-LAYOUT
Kent Cooper, AIA
