My drawing is in meters, and I'm trying to set my plotting layout to millimeters and set my drawing to a scale to 1:100. However, when I set my plotting size to 700 x 700mm, the layout space converts that to 27 x 27 inches, and then my drawing (which was in meters) is now also in inches. So my floor plan which is 7m wide and obviously shouldn't fit at 1:1 fits perfectly since the layout recognizes it as 7 inches instead of meters. This is driving me insane, and I'm not sure if I'm missing a simple step. I sincerely appreciate any help.
Ryan
Solved by skeramidas. Go to Solution.
Solved by ВeekeeCZ. Go to Solution.
hello, have you check your DDUNITS set your unit format. thanks
yes, like I said, my ddunits are in meters, but somehow the layout makes the units inches instead...
To reiterate, I changed my drawing units from meters to inches and converted my floor plan from 7m wide to 275 inches wide. This lets me scale the drawing properly in layout because it will only do inches!
hello, is there anyway you can post your drawings here so we can check. thanks
try this in the command prompt type -DWGUNITS and select your units. thanks
Here's the drawing. I'm trying to make it 1:100. One floor in real size is 7m wide, so it should be 7cm in layout.
I would do it like this.
Used -dwgunits to change the units to m. Without scaling.
Layout sheet I draw in mm, so its 700x700, or 1400x700 to fit drawing.
Then the scale is 10.
Should anyone arrive here, the problem was solved here https://forums.autodesk.com/t5/autocad-forum/plot-size-units/m-p/6435416#M133282
Setting MEASUREMENT to 1 solved my inches in layout problem
