Hi Guys,
I am with struggling trying figure out whats going on with a file when i plot then in PDF, the layers block seems to be too weight when i have to make a zoom. does anyone how to sort that? see the screen shot File attached.
Solved by ChicagoLooper. Go to Solution.
can you make a screenshot for your Plot dialog settings and attache it here ?
Imad Habash
Are those raster images? Nothing in your posted PDF would indicate you have a problem, which does not match your pretty picture, and you have all methods of setting line weights turned off in AutoCAD LT 2021.
So how can we help exactly?
hi @pendean, i appreciate yours thoughts,
I attached the file as asked by @imadHabash for check that. Besides, the file was drew already upon scale 1:1, the issue that has running in here it is about the layers when i have to plot the file in PDF, some them, continue be very weight, even that i've had kept this adjusted on the layers attributes. see the email on the top if you would like to help.
one more time, thank for your effort been in here trying to help.
So the black rectangle with the white objects and white text is a block, correct? If this is correct, then check the layer hosting the block.
What is block's layer lineweight in the Layers Properties Manager? When the block is selected, what is displayed under the Lineweight section in the Properties Palette, By Layer? Or something else? For best results, the lineweight for the block should be controlled by the layer hosting the block, not controlled through the Properties Manager.
Chicagolooper
