Layer won’t display in Layout
Message 1 of 14
No matter what I do I can’t get several layers to display in a Layout. The layers are from an XRef. I don’t know if that matters. What could be going on?
Replies (13)
Message 2 of 14
elshawadfy
Make sure they are on & Thawed in the model ..
In the ViewPort, make sure they are Thawed in that specific viewport..
Note:
- That if the objects are drawn on layer 0 will take the appearance of the layer that the block is inserted in, not that of their original layer.. and will disappear when freezing or turning off the layer of insertion, not layer 0..
- The objects that have their color set to byblockwill also take the appearance of the layer that the block is inserted in, but will be turned off according to their original layers not the layer of insertion.. and will disappear also when either their original layer or the layer of insertion is frozen..
So make sure you're dealing with the right layers..
Message 3 of 14
To check that layer are ON and THAWED I went to the model tab,  executed LAYER command.  The relevant layers are ON and THAWED.  I also executed LAYERSTATE and restored the relevant view, they clicked edit and looked at the layers while on model tab.  they are ON and THAWED.
Regarding what layers the objects are on, I don't know how to check that.
The objects are from an XRef.
Here is what the LAYER command shows.
The layers that won't display are the ones starting with PINOLE7:
and that are shown as ON and THAWED.
So aren't the relevant objects in those layers?  And they are ON and THAWED.
Message 4 of 14
Alfred.NESWADBA
change to layout, double click into the viewport where you are missing objects, then again start command _LAYER and you'll see that the layer manager show additionel columns. These columns control how the layer should be represented in the current viewport ... and also the column VPFreeze (freeze layer only in that viewport).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 14
Thank you.  That helped display a couple of layers that had VPFreeze set to freeze.  However, it did not solve the problem with the XRef layers starting with "Pinole7:"  Here is what LAYER shows.  VPFreeze is off and the layers are set ON and THAWED, but they still don't display in the Layout viewport.
Message 6 of 14
Would anyone be willing to look at the file?  And, if so, can I attach it?  I don't readily see a way to do that.
Message 7 of 14
ВeekeeCZ
Sure.
Message 8 of 14
Alfred.NESWADBA
In the answer to the thread you have the body text, below of that the option to insert paths to screencasts and again below of that you can attach files.
Use command _ETRANSMIT from your drawing so a zip is created with main drawing and referenced drawings and then upload this zip file.
- alfred -
Alfred NESWADBA
Message 9 of 14
I solved it, with the clue about layers for the block.
The Xref block was on a layer that was turned off, so all the layers in the block were off.
Message 10 of 14
Thank you to those who volunteered to look at the file.
As noted in my previous reply, I found the problem: Xref on a layer that was off, so all the layers in the xref were off (even though they say ON in LAYER window)
Message 11 of 14
elshawadfy
Congratulations for solving your problem @Anonymous !!
But I think what you meant is that that the layer whre the xref is inserted was Frozen not Off, unless the objects inside your xref where in layer "0" (My first note n my first reply)...
Message 12 of 14
kevin
Issue; Xref'd AnnoText (multiscale text) showed up in model space but not in paperspace viewport.  Tried many layer checks, layer 0, defpoints, purge, audit, purge, recover types, to fix, no go.  Thought it was a corrupt Viewport however:  the work around was to go into the Xref dwg, create new Text, erase the Annotext....  not sure if there is some Annotext/Viewport (maybe rotated UCS) related sysvar toggle issue causing a failure to display in PS....?
The solution defeats the purpose of annotext.  The fix might be in the Annotext code.
Are similar threads on this Viewport issue Annotext also?
Message 13 of 14
kevin
Set  ANNOALLVISIBLE  to 1
Message 14 of 14
Fixed my problem!!
Stan
