Anuncios
Layer States help
Layer States help
No aplicable
OK
First time posting, our Cad Manager left and Im the stop gate for now, I work for a medium sizeproduction builder and here is the road block:
I need to add a few layers to our cad standard template, we use layer states for the entire template. the problem is when I go in to the dialog box - add the layers to the appropriate layer state - freize /alow to show it deosnt function correctly. I have tried to research this but info is vauge.
am I to add all the dnew layers to each layer state then frieze/thaw?? this is how it seems set up to begin with.
Any help would be wanderful - I am up against a huge deadline and our drafters are working with out a complete template.
Thanks for your consideration.
Sincerely, Paul
0 Me gusta
Responder
Soluciones aceptadas (2)
496 Vistas
5 Respuestas
Respuestas (5)
stevetamplen
Hello Paul and welcome to the Forums!
After it is created, when you edit the layer state in the Layer States dialog box, you should be able to set the options (Freeze, Off, etc.).
If that is not the case, can you please send us a screenshot or Screencast of the issue?
Steve Tamplen
Technical Support Specialist
0 Me gusta
jporter
Solución aceptada
Theses may help:
https://m.youtube.com/?#/watch?v=9TyttfBD55Q
https://m.youtube.com/?#/watch?v=dCCULxQ4Wdc
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
No aplicable
Im going to check out Jasons links but here is a screen shot:
0 Me gusta
stevetamplen
Solución aceptada
Hi Paul;
I can't see the top of the window, but capture2 appears to be the Edit Layer State dialog box, where you can make changes to an existing layer state.
So the workflow is:
1. Put layers into the state you want them displayed (some on, some off, a couple frozen, etc.)
2. Create a Layer State from that configuration
3. Give it a name describing that configuration (Wiring, Piping, Walls, etc.) and put in a short description if needed
4. If you made a mistake, or decide you want to make a change, edit that Layer State and make changes to fit what you want displayed
I recommend you watch the 2 Youtube videos (thanks jporter!) as they are both good instructional videos for how to use Layer States.
Steve Tamplen
0 Me gusta
No aplicable
10-4 working thru this with a bit of guidance all seems to be functioning correctly - some of my issue was the first state (ALL ON) didnt have the new layers I created / added and working.
Thanks all so much.
P
0 Me gusta
