Layer Properties not showing
revit1980
revit1980
Hello
When i click the layer Properties my layer lists are not displaying.
I am getting message to put enter an option.
I only want to list my layers.How can i fix it.Please help
imadHabash
you will have this list of layer options when you type   -LAYER command !! try to type in your commandline ( as a test ) LAYER command , any changes ? Now .. when you press your ribbon layer button , what will you get down there ?
you may need :
  • check your version update from your Autodesk Desktop App .
  • reset AutoCAD to default settings . >> Click <<
Imad Habash
ennujozlagam
you can refer to this LINK and see if helps. thanks
revit1980
Thanks Resetting AutoCAD bring up the Layer palette.
