Anuncios
Layer Properties Manager - Text, etc. TOO SMALL!
RAFUSE
RAFUSE
Is there any way to make the text and symbols larger?
I have a real difficulty in seeing whether, for example, the status a VP Freeze.
I do want to keep the status bar "small".
R
0 Me gusta
Responder
273 Vistas
8 Respuestas
Respuestas (8)
pendean
Community Legend
Community Legend
Show us what you see please: post screenshots.
Also tell us about your setup: what screen size and resolution are you using the program in, and did you also change the text size in Windows display settings too?
0 Me gusta
jayhar
Can't change text height in Layer Properties Manager.
Can use Large button for Toolbars.
For text scales or displays incorrectly >>>Click here
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
0 Me gusta
RAFUSE
24" SCREEN, 1920 X 1200, 60HZ, RGB,
Changed Windows text size but it had no apparent effect on ACAD.
Not sure what else you want.
R
0 Me gusta
pendean
Community Legend
Community Legend
@RAFUSE wrote:
... Not sure what else you want.
R
Show us what you see please: post screenshots: if you are not sure how, read this https://support.microsoft.com/en-us/help/13776/windows-use-snipping-tool-to-capture-screenshots
0 Me gusta
RAFUSE
Auto Desk dropped the ball here.  The symbols are just too small to see whether, for example, VP freeze is on or off.  Older versions were ok.
R
0 Me gusta
pendean
Community Legend
Community Legend
@RAFUSE wrote:
...Older versions were ok.
R
Which older versions?
What are you using now?
Screenshots please.
@RAFUSE wrote:
Auto Desk dropped the ball here...
Then reach out to Autodesk direct, these forums are not that: Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
0 Me gusta
RAFUSE
Sorry it took so long.
Here is a screen shot to show how small the "icons" are.
I cannot see when, for example, a view port layer is frozen or not.
0 Me gusta
pendean
Community Legend
Community Legend
@RAFUSE What is your monitor scaling set at, it looks fine if you are truly running "...24" SCREEN, 1920 X 1200, 60HZ..."? This looks 100% normal but on my 27" screens (same resolution as yours) and it's identical to my layer list, very readable. Not sure an extra 3" diagonal is going to make that much difference but perhaps it does.
Or would you consider a darker background with less washed out icons?
0 Me gusta
